经过反复测试,0.47的系统好用,但升级到0.62就挂了,请麻烦看看原因,下面是启动过程
就是啥都不变,只从uboot里面刷0.47和0.62然后分别对比
0.47一切正常可以进入系统
SuperWRT Boot 1.2.9-g0d478f41-dirty (Mar 19 2017 - 23:02:02)
QCA955x - Scorpion 1.0
DRAM: 128 MB
Flash: 16 MB (12018)
Frequency: CPU 720MHz / RAM 600MHz / AHB 240MHz
Bootstrap Config: 0x00021e5c
AE5000-E2CN2/mcpcloud@126.com/2017-05-07
WLAN0 info: cal:0x9fff1000, mac:0x9fff0000
WLAN1 info: cal:0x9fff5000, mac:0x9fff0006
Device UID: 8a611fb2bceff86541fa9f1c1e174f97
GPIO: reset(-1/L), system(-1/L)
Net: (b8:ee:65:01:00:20) S17 eth0
Set 0x18116290 = 0x4c98214f
Hit 'c' or 'Ctrl+c' to stop autoboot: 1
Net Command waiting: 2
Try eth1 first.
eth0 link down
Retry start!
eth0 link down
config: Config magic check error!
config2: Config magic check error!
## Booting image at 9f020000 ...
Image Name: SuperWrt qca/qca9k/std
Created: 2017-05-05 9:37:26 UTC
Data Size: 1293340 Bytes = 1.2 MB
Verifying Checksum at 0x9f020178 ...OK
[ 0.000000] Linux version 3.18.47 (terra@localhost.localdomain) (gcc version 4.8.3 (SuperWrt/Linaro GCC 4.8-2014.04 r44747) ) #1 Fri May 5 17:35:47 CST 2017
[ 0.000000] CPU0 revision is: 00019750 (MIPS 74Kc)
[ 0.000000] SoC: Qualcomm Atheros QCA9558 ver 1 rev 0
[ 0.000000] memory: 08000000 @ 00000000 (usable)
[ 0.000000] Normal [mem 0x00000000-0x07ffffff]
[ 0.000000] node 0: [mem 0x00000000-0x07ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x00000000-0x07ffffff]
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: console=ttyS0,115200 mtdparts=spi0.0:112k(uboot),16k(SBI),11520k(firmware),4160k(udata),64k(elog),128k(config),128k(config2),128k(custom),64k(DTB),64k(CAL) mem=128M sbi=0x9f01c000 rootfstype=squashfs,jffs2 init=/sbin/init noinitrd rootfstype=squashfs,jffs2 init=/sbin/init noinitrd
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 125500K/131072K available (3085K kernel code, 169K rwdata, 416K rodata, 160K init, 163K bss, 5572K reserved)
[ 0.000000] NR_IRQS:51
[ 0.000000] Clocks: CPU:720.000MHz, DDR:600.000MHz, AHB:240.000MHz, Ref:40.000MHz
[ 0.000000] Calibrating delay loop... 359.42 BogoMIPS (lpj=718848)
[ 0.028000] pid_max: default: 32768 minimum: 301
[ 0.032000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.036000] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.040000] NET: Registered protocol family 16
[ 0.044000] MIPS: machine is SuperWRT
[ 0.048000] registering PCI controller with io_map_base unset
[ 0.052000] ar724x-pci ar724x-pci.1: PCIe link is down
[ 0.056000] registering PCI controller with io_map_base unset
[ 0.272000] SCSI subsystem initialized
[ 0.276000] usbcore: registered new interface driver usbfs
[ 0.280000] usbcore: registered new interface driver hub
[ 0.284000] usbcore: registered new device driver usb
[ 0.288000] PCI host bridge to bus 0000:00
[ 0.292000] pci_bus 0000:00: root bus resource [mem 0x10000000-0x11ffffff]
[ 0.296000] pci_bus 0000:00: root bus resource [io 0x0000]
[ 0.300000] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[ 0.304000] pci 0000:00:00.0: invalid calibration data
[ 0.308000] pci 0000:00:00.0: BAR 0: assigned [mem 0x10000000-0x101fffff 64bit]
[ 0.312000] pci 0000:00:00.0: BAR 6: assigned [mem 0x10200000-0x1020ffff pref]
[ 0.316000] PCI host bridge to bus 0000:01
[ 0.320000] pci_bus 0000:01: root bus resource [mem 0x12000000-0x13ffffff]
[ 0.324000] pci_bus 0000:01: root bus resource [io 0x0001]
[ 0.328000] pci_bus 0000:01: No busn resource found for root bus, will use [bus 01-ff]
[ 0.332000] pci 0000:00:00.0: using irq 40 for pin 1
[ 0.336000] Switched to clocksource MIPS
[ 0.340000] NET: Registered protocol family 2
[ 0.344000] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.352000] TCP bind hash table entries: 1024 (order: 2, 20480 bytes)
[ 0.360000] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.368000] TCP: reno registered
[ 0.372000] UDP hash table entries: 256 (order: 1, 12288 bytes)
[ 0.376000] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[ 0.384000] NET: Registered protocol family 1
[ 0.392000] futex hash table entries: 256 (order: 0, 7168 bytes)
[ 0.412000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.416000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.428000] msgmni has been set to 245
[ 0.444000] io scheduler noop registered
[ 0.448000] io scheduler deadline registered (default)
[ 0.452000] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[ 0.460000] console [ttyS0] disabled
[ 0.484000] serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11, base_baud = 2500000) is a 16550A
[ 0.496000] console [ttyS0] enabled
[ 0.500000] bootconsole [early0] disabled
[ 0.512000] m25p80 spi0.0: found s25fl129p1, expected m25p80
[ 0.520000] m25p80 spi0.0: s25fl129p1 (16384 Kbytes)
[ 0.524000] 10 cmdlinepart partitions found on MTD device spi0.0
[ 0.528000] Creating 10 MTD partitions on "spi0.0":
[ 0.536000] 0x000000000000-0x00000001c000 : "uboot"
[ 0.540000] 0x00000001c000-0x000000020000 : "SBI"
[ 0.548000] 0x000000020000-0x000000b60000 : "firmware"
[ 0.552000] Split rootfs Part: off:0 len:0
[ 0.556000] 0x00000015bd98-0x000000b60000 : "rootfs"
[ 0.564000] mtd: device 3 (rootfs) set to be root filesystem
[ 0.568000] 1 squashfs-split partitions found on MTD device rootfs
[ 0.576000] 0x000000360000-0x000000b60000 : "rootfs_data"
[ 0.580000] 0x000000b60000-0x000000f70000 : "udata"
[ 0.588000] 0x000000f70000-0x000000f80000 : "elog"
[ 0.592000] mtdoops: MTD partition 6 not big enough for mtdoops
[ 0.596000] 0x000000f80000-0x000000fa0000 : "config"
[ 0.604000] 0x000000fa0000-0x000000fc0000 : "config2"
[ 0.608000] 0x000000fc0000-0x000000fe0000 : "custom"
[ 0.616000] 0x000000fe0000-0x000000ff0000 : "DTB"
[ 0.620000] 0x000000ff0000-0x000001000000 : "CAL"
[ 0.636000] switch0: Atheros AR8337 rev. 2 switch registered on ag71xx-mdio.0
[ 0.732000] libphy: ag71xx_mdio: probed. phys=0x01ff001f
[ 1.304000] eth0: Atheros AG71xx at 0xb9000000, irq 4, mode:SGMII
[ 1.308000] PPP generic driver version 2.4.2
[ 1.316000] NET: Registered protocol family 24
[ 1.320000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.324000] ehci-pci: EHCI PCI platform driver
[ 1.332000] ehci-platform: EHCI generic platform driver
[ 1.336000] ehci-platform ehci-platform.0: EHCI Host Controller
[ 1.340000] ehci-platform ehci-platform.0: new USB bus registered, assigned bus number 1
[ 1.352000] ehci-platform ehci-platform.0: TX-TX IDP fix enabled
[ 1.356000] ehci-platform ehci-platform.0: irq 48, io mem 0x1b000000
[ 1.376000] ehci-platform ehci-platform.0: USB 2.0 started, EHCI 1.00
[ 1.380000] hub 1-0:1.0: USB hub found
[ 1.384000] hub 1-0:1.0: 1 port detected
[ 1.388000] ehci-platform ehci-platform.1: EHCI Host Controller
[ 1.396000] ehci-platform ehci-platform.1: new USB bus registered, assigned bus number 2
[ 1.408000] ehci-platform ehci-platform.1: TX-TX IDP fix enabled
[ 1.412000] ehci-platform ehci-platform.1: irq 49, io mem 0x1b400000
[ 1.432000] ehci-platform ehci-platform.1: USB 2.0 started, EHCI 1.00
[ 1.436000] hub 2-0:1.0: USB hub found
[ 1.440000] hub 2-0:1.0: 1 port detected
[ 1.444000] usbcore: registered new interface driver usblp
[ 1.452000] usbcore: registered new interface driver usb-storage
[ 1.456000] Netfilter messages via NETLINK v0.30.
[ 1.464000] nf_conntrack version 0.5.0 (1960 buckets, 7840 max)
[ 1.468000] xt_time: kernel timezone is -0000
[ 1.476000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.480000] TCP: cubic registered
[ 1.484000] NET: Registered protocol family 10
[ 1.488000] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.496000] NET: Registered protocol family 17
[ 1.500000] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.512000] Ebtables v2.0 registered
[ 1.516000] 8021q: 802.1Q VLAN Support v1.8
[ 1.528000] VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
[ 1.536000] Freeing unused kernel memory: 160K (803f8000 - 80420000)
init started: BusyBox v1.22.1 (2017-05-05 17:31:19 CST)
starting pid 357, tty '': 'sh /etc/init.d/rcS S start'
mount: mounting usbfs on /proc/bus/usb failed: No such file or directory
mount: mounting nodev on /sys/kernel/debug failed: No such file or directory
Fri Jan 1 00:00:00 UTC 2010
Try backup config
[ 3.552000] Loading modules backported from Linux version wt-2016-10-03-1-g6fcb1a6
[ 3.560000] Backport generated by backports.git backports-20160324-9-g0e38f5c
[ 3.924000] swd: module license 'Proprietary' taints kernel.
[ 3.932000] Disabling lock debugging due to kernel taint
[ 3.936000] SuperWRT Network Engine installed!sh: bad number
sh: bad number
[ 4.176000] ieee80211 phy0: Atheros AR9550 Rev:0 mem=0xb8100000, irq=47
[ 4.300000] PCI: Enabling device 0000:00:00.0 (0000 -> 0002)
[ 4.308000] ath10k_pci 0000:00:00.0: pci irq legacy oper_irq_mode 1 irq_mode 0 reset_mode 0
[ 4.504000] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:00:00.0.bin failed with error -2
[ 4.516000] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/cal-pci-0000:00:00.0.bin failed with error -2
[ 4.732000] ath10k_pci 0000:00:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043222ff sub 0000:0000
[ 4.740000] ath10k_pci 0000:00:00.0: kconfig debug 0 debugfs 0 tracing 0 dfs 1 testmode 0
[ 4.752000] ath10k_pci 0000:00:00.0: firmware ver 10.2.4.70.59-2 api 5 features no-p2p,raw-mode,mfp crc32 4159f498
[ 4.804000] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
[ 4.816000] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board.bin failed with error -2
[ 4.824000] ath10k_pci 0000:00:00.0: board_file api 1 bmi_id N/A crc32 00000000
[ 4.920000] ath10k_pci 0000:00:00.0: failed to get board id form OTP: -122
[ 5.976000] ath10k_pci 0000:00:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal file max-sta 128 raw 0 hwcrypto 1
brctl: bridge lan: File exists
brctl: bridge glan: File exists
[ 6.180000] random: svld urandom read with 24 bits of entropy available
sh: bad number
sh: bad number
[ 7.560000] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.568000] device wlan0 entered promiscuous mode
[ 13.708000] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
sh: bad number
sh: bad number
[ 14.064000] ath10k_pci 0000:00:00.0: failed to get board id form OTP: -122
[ 15.160000] IPv6: ADDRCONF(NETDEV_UP): wlan10: link is not ready
[ 15.172000] device wlan10 entered promiscuous mode
[ 21.952000] IPv6: ADDRCONF(NETDEV_CHANGE): wlan10: link becomes ready
[ 22.292000] eth0: link up (1000Mbps/Full duplex)
ifconfig: SIOCSIFADDR: No such device
[ 22.328000] device eth0.1 entered promiscuous mode
[ 22.332000] device eth0 entered promiscuous mode
[ 22.344000] lan: port 3(eth0.1) entered forwarding state
[ 22.348000] lan: port 3(eth0.1) entered forwarding state
[ 22.352000] lan: port 2(wlan10) entered forwarding state
[ 22.360000] lan: port 2(wlan10) entered forwarding state
[ 22.364000] lan: port 1(wlan0) entered forwarding state
[ 22.368000] lan: port 1(wlan0) entered forwarding state
/etc/swrt/service/S36netwan/run: line 68: can't create /proc/swd/nscd/dns_ips/dns_ips: nonexistent directory
udhcpc (v1.22.1) started
Setting IP address 0.0.0.0 on eth0.2
Sending discover...
no schk found; none killed
no httpd found; none killed
Performing a DHCP renew
Jan 1 08:00:20 crond[820]: crond: crond (busybox 1.22.1) started, log level 8. random: 1734213659.
starting pid 823, tty '': '/sbin/getty -L -a'
SuperWRT login: [ 24.232000] random: nonblocking pool is initialized
Sending discover...
SuperWRT login: Sending discover...
0.62启动后就挂了 启动信息如下
SuperWRT Boot 1.3.6-gf7fef81e-dirty (Sep 12 2017 - 16:14:14)
DRAM: 128 MB
Net: (b8:ee:65:01:00:20) S17 [RGMII CALED: XMII=0x00000000 ETH_CFG=0x0003c001] eth0
Try eth1 first.
eth0 link down
Retry start!
eth0 link down
Created: 2017-09-12 8:13:14 UTC
Data Size: 1301030 Bytes = 1.2 MB
[ 0.000000] Linux version 3.18.47 (terra@localhost.localdomain) (gcc version 4.8.3 (SuperWrt/Linaro GCC 4.8-2014.04 r44747) ) #1 Tue Sep 12 16:11:26 CST 2017
[ 0.000000] Memory: 125428K/131072K available (3103K kernel code, 172K rwdata, 420K rodata, 200K init, 171K bss, 5644K reserved)
[ 0.428000] msgmni has been set to 244
[ 0.436000] io scheduler noop registered
[ 0.440000] io scheduler deadline registered (default)
[ 0.444000] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[ 0.452000] console [ttyS0] disabled
[ 0.476000] serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11, base_baud = 2500000) is a 16550A
[ 0.484000] console [ttyS0] enabled
[ 0.492000] bootconsole [early0] disabled
[ 0.532000] Creating 10 MTD partitions on "spi0.0":
[ 0.552000] Split rootfs Part: off:0x15dba0 len:0xa02460
[ 0.556000] 0x00000015dba0-0x000000b60000 : "rootfs"
[ 0.564000] 1 squashfs-split partitions found on MTD device rootfs
[ 0.572000] 0x000000390000-0x000000b60000 : "rootfs_data"
[ 0.576000] mtd: device 3 (rootfs) set to be root filesystem
[ 0.600000] 0x000000f80000-0x000000fa0000 : "config"
[ 0.612000] 0x000000fc0000-0x000000fe0000 : "custom"
[ 0.640000] switch0: Atheros AR8337 rev. 2 switch registered on ag71xx-mdio.0
[ 1.308000] eth0: Atheros AG71xx at 0xb9000000, irq 4, mode:SGMII
[ 1.312000] PPP generic driver version 2.4.2
[ 1.320000] PPP MPPE Compression module registered
[ 1.324000] NET: Registered protocol family 24
[ 1.328000] PPTP driver version 0.8.5
[ 1.332000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.340000] ehci-pci: EHCI PCI platform driver
[ 1.344000] ehci-platform: EHCI generic platform driver
[ 1.348000] ehci-platform ehci-platform.0: EHCI Host Controller
[ 1.356000] ehci-platform ehci-platform.0: new USB bus registered, assigned bus number 1
[ 1.364000] ehci-platform ehci-platform.0: TX-TX IDP fix enabled
[ 1.372000] ehci-platform ehci-platform.0: irq 48, io mem 0x1b000000
[ 1.388000] ehci-platform ehci-platform.0: USB 2.0 started, EHCI 1.00
[ 1.392000] hub 1-0:1.0: USB hub found
[ 1.396000] hub 1-0:1.0: 1 port detected
[ 1.400000] ehci-platform ehci-platform.1: EHCI Host Controller
[ 1.408000] ehci-platform ehci-platform.1: new USB bus registered, assigned bus number 2
[ 1.420000] ehci-platform ehci-platform.1: TX-TX IDP fix enabled
[ 1.424000] ehci-platform ehci-platform.1: irq 49, io mem 0x1b400000
[ 1.444000] ehci-platform ehci-platform.1: USB 2.0 started, EHCI 1.00
[ 1.448000] hub 2-0:1.0: USB hub found
[ 1.452000] hub 2-0:1.0: 1 port detected
[ 1.456000] usbcore: registered new interface driver usblp
[ 1.464000] usbcore: registered new interface driver usb-storage
[ 1.468000] Netfilter messages via NETLINK v0.30.
[ 1.476000] nf_conntrack version 0.5.0 (1959 buckets, 7836 max)
[ 1.480000] xt_time: kernel timezone is -0000
[ 1.488000] gre: GRE over IPv4 demultiplexor driver
[ 1.492000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.496000] TCP: cubic registered
[ 1.500000] NET: Registered protocol family 10
[ 1.508000] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.512000] NET: Registered protocol family 17
[ 1.516000] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 1.528000] Ebtables v2.0 registered
[ 1.532000] 8021q: 802.1Q VLAN Support v1.8
[ 1.544000] VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
[ 1.552000] Freeing unused kernel memory: 200K (803fe000 - 80430000)
init started: BusyBox v1.22.1 (2017-09-12 16:05:49 CST)
starting pid 352, tty '': 'sh /etc/init.d/rcS S start'
Try backup config
[ 3.572000] Loading modules backported from Linux version wt-2016-10-03-1-g6fcb1a6
[ 3.580000] Backport generated by backports.git backports-20160324-9-g0e38f5c
[ 3.972000] swd: module license 'Proprietary' taints kernel.
[ 3.980000] Disabling lock debugging due to kernel taint
[ 3.988000] SuperWRT Network Engine installed!
[ 4.256000] ieee80211 phy0: Atheros AR9550 Rev:0 mem=0xb8100000, irq=47
[ 4.432000] PCI: Enabling device 0000:00:00.0 (0000 -> 0002)
[ 4.436000] ath10k_pci 0000:00:00.0: pci irq legacy oper_irq_mode 1 irq_mode 0 reset_mode 0
[ 4.632000] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:00:00.0.bin failed with error -2
[ 4.644000] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/cal-pci-0000:00:00.0.bin failed with error -2
[ 4.860000] ath10k_pci 0000:00:00.0: qca988x hw2.0 target 0x4100016c chip_id 0x043222ff sub 0000:0000
[ 4.868000] ath10k_pci 0000:00:00.0: kconfig debug 0 debugfs 0 tracing 0 dfs 1 testmode 0
[ 4.880000] ath10k_pci 0000:00:00.0: firmware ver 10.2.4.70.59-2 api 5 features no-p2p,raw-mode,mfp crc32 4159f498
[ 4.932000] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board-2.bin failed with error -2
[ 4.944000] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA988X/hw2.0/board.bin failed with error -2
[ 4.952000] ath10k_pci 0000:00:00.0: board_file api 1 bmi_id N/A crc32 00000000
[ 5.048000] ath10k_pci 0000:00:00.0: failed to get board id form OTP: -122
[ 6.104000] ath10k_pci 0000:00:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal file max-sta 128 raw 0 hwcrypto 1
[ 6.380000] random: svld urandom read with 25 bits of entropy available
[ 32.044000] NMI watchdog: BUG: soft lockup - CPU#0 stuck for 22s! [switchc:513]
[ 32.044000] Modules linked in: ath10k_pci[0x87268000] ath10k_core[0x87280000] ath9k[0x87050000] ath9k_common[0x87b88000] ath9k_hw[0x87000000] ath[0x87ba8000] swdgpl[0x87ba2000] swd(P)[0x87b60000] mac80211[0x87080000] cfg80211[0x87bc0000] compat[0x87b5c000]
[ 32.044000] CPU: 0 PID: 513 Comm: switchc Tainted: P 3.18.47 #1
[ 32.044000] task: 87b32cb8 ti: 86ea6000 task.ti: 86ea6000
[ 32.044000] $ 0 : 00000000 00b40134 000000b3 b69f5000
[ 32.044000] $ 4 : 00000295 0000037f 00000003 00008000
[ 32.044000] $ 8 : 00000003 80064f3c 4b3d3b0f 00000201
[ 32.044000] $12 : 04000000 86e3e424 00000000 00080002
[ 32.044000] $16 : 000003e7 878e9600 00001005 00000010
[ 32.044000] $20 : 86ea7b28 879c0cc6 879c01d4 86ea7bb0
[ 32.044000] $24 : 00000000 8022db18
[ 32.044000] $28 : 86ea6000 86ea7a70 879c0a27 8022d9cc
[ 32.044000] Hi : 00000003
[ 32.044000] Lo : 911c9000
[ 32.044000] epc : 801a57e8 0x801a57e8
[ 32.044000] Tainted: P
[ 32.044000] ra : 8022d9cc 0x8022d9cc
[ 32.044000] Status: 1100dc03 KERNEL EXL IE
[ 32.044000] Cause : 40808000
[ 32.044000] PrId : 00019750 (MIPS 74Kc)
