求助刷了好几个固件都卡在这里,AR9344的
chenqw8
注册: 周二 11月 24, 2020 11:42 am
帖子chenqw8 » 周日 11月 29, 2020 10:29 pm
刷了好几个固件都卡在这里,信息如下:
网站定制的UBOOT,进网页刷的固件
SuperWRT Boot 1.3.11-dirty (Oct 23 2019 - 18:02:52)
AR9344 - Wasp 1.2
DRAM: 128 MB
Unkonw try using 16777216 MB
Flash: 16 MB (20ba19)
Frequency: CPU 560MHz / RAM 449MHz / AHB 224MHz
Bootstrap Config: 0x00ab055e
HW/365397037@qq.com/2020-11-29
WLAN1 info: cal:0x9fff5000, mac:0x9fff0006
Device UID: none
GPIO: reset(-1/L), system(-1/L)
Net: (02:54:65:72:72:61) 8035 S27 eth0, eth1
Set 0x18116290 = 0x20402d0f
Hit 'c' or 'Ctrl+c' to stop autoboot: 1
Net Command waiting: 2
Try eth1 first.
eth1 link down
dup 1 speed 100
config: Config magic check error!
config2: Config magic check error!
## Booting image at 9f020000 ...
Image Name: SuperWrt qca/qca9k/pro
Created: 2020-11-20 9:06:17 UTC
Data Size: 1384819 Bytes = 1.3 MB
Verifying Checksum at 0x9f020190 ...OK
[ 0.000000] Linux version 3.18.47 (terra@localhost.localdomain) (gcc version 4.8.3 (SuperWrt/Linaro GCC 4.8-2014.04 r44747) ) #1 Fri Nov 20 17:04:18 CST 2020
[ 0.000000] CPU0 revision is: 0001974c (MIPS 74Kc)
[ 0.000000] SoC: Atheros AR9344 rev 2
[ 0.000000] memory: 08000000 @ 00000000 (usable)
[ 0.000000] Normal [mem 0x00000000-0x07ffffff]
[ 0.000000] node 0: [mem 0x00000000-0x07ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x00000000-0x07ffffff]
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 32512
[ 0.000000] Kernel command line: console=ttyS0,115200 mtdparts=spi0.0:128k(u boot),11520k(firmware),4160k(udata),64k(elog),128k(config),128k(config2),128k(cu stom),64k(DTB),64k(CAL) mem=128M sbi=0x9f01c000 rootfstype=squashfs,jffs2 init=/ sbin/init noinitrd
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 125236K/131072K available (3145K kernel code, 230K rwdata , 548K rodata, 164K init, 171K bss, 5836K reserved)
[ 0.000000] NR_IRQS:51
[ 0.000000] Clocks: CPU:560.000MHz, DDR:450.000MHz, AHB:225.000MHz, Ref:40.00 0MHz
[ 0.000000] Calibrating delay loop... 278.78 BogoMIPS (lpj=557568)
[ 0.040000] pid_max: default: 32768 minimum: 301
[ 0.044000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.048000] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.052000] NET: Registered protocol family 16
[ 0.056000] MIPS: machine is SuperWRT
[ 0.484000] SCSI subsystem initialized
[ 0.488000] usbcore: registered new interface driver usbfs
[ 0.492000] usbcore: registered new interface driver hub
[ 0.496000] usbcore: registered new device driver usb
[ 0.500000] Switched to clocksource MIPS
[ 0.504000] NET: Registered protocol family 2
[ 0.508000] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.516000] TCP bind hash table entries: 1024 (order: 2, 20480 bytes)
[ 0.524000] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.532000] TCP: reno registered
[ 0.536000] UDP hash table entries: 256 (order: 1, 12288 bytes)
[ 0.540000] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[ 0.548000] NET: Registered protocol family 1
[ 0.556000] futex hash table entries: 256 (order: 0, 7168 bytes)
[ 0.568000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.576000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (CMODE_PRIORITY) (c) 2 001-2006 Red Hat, Inc.
[ 0.588000] msgmni has been set to 244
[ 0.596000] io scheduler noop registered
[ 0.600000] io scheduler deadline registered (default)
[ 0.608000] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[ 0.616000] console [ttyS0] disabled
[ 0.640000] serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11, base_baud = 250 0000) is a 16550A
[ 0.648000] console [ttyS0] enabled
[ 0.656000] bootconsole [early0] disabled
[ 0.688000] m25p80 spi0.0: found n25q256a, expected m25p80
[ 0.692000] m25p80 spi0.0: n25q256a (32768 Kbytes)
[ 0.696000] 9 cmdlinepart partitions found on MTD device spi0.0
[ 0.704000] Creating 9 MTD partitions on "spi0.0":
[ 0.708000] 0x000000000000-0x000000020000 : "uboot"
[ 0.716000] 0x000000020000-0x000000b60000 : "firmware"
[ 0.720000] 0x000000b60000-0x000000f70000 : "udata"
[ 0.728000] 0x000000f70000-0x000000f80000 : "elog"
[ 0.732000] mtdoops: Attached to MTD device 3
[ 0.736000] 0x000000f80000-0x000000fa0000 : "config"
[ 0.744000] 0x000000fa0000-0x000000fc0000 : "config2"
[ 0.748000] 0x000000fc0000-0x000000fe0000 : "custom"
[ 0.756000] 0x000000fe0000-0x000000ff0000 : "DTB"
[ 0.760000] 0x000000ff0000-0x000001000000 : "CAL"
[ 0.784000] libphy: ag71xx_mdio: probed. phys=0x0000001f
[ 0.792000] libphy: ag71xx_mdio: probed. phys=0x00000010
[ 1.428000] ag71xx ag71xx.0: connected to PHY at ag71xx-mdio.0:04 [uid=004dd0 72, driver=Atheros 8035 ethernet]
[ 1.436000] eth0: Atheros AG71xx at 0xb9000000, irq 4, mode:RGMII
[ 2.012000] ag71xx-mdio.1: Found an AR934X built-in switch
[ 2.052000] eth1: Atheros AG71xx at 0xba000000, irq 5, mode:GMII
[ 2.056000] PPP generic driver version 2.4.2
[ 2.064000] PPP MPPE Compression module registered
[ 2.068000] NET: Registered protocol family 24
[ 2.072000] PPTP driver version 0.8.5
[ 2.076000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.084000] ehci-pci: EHCI PCI platform driver
[ 2.088000] ehci-platform: EHCI generic platform driver
[ 2.092000] ehci-platform ehci-platform: EHCI Host Controller
[ 2.100000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
[ 2.108000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
[ 2.128000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
[ 2.132000] hub 1-0:1.0: USB hub found
[ 2.136000] hub 1-0:1.0: 1 port detected
[ 2.144000] usbcore: registered new interface driver usblp
[ 2.148000] usbcore: registered new interface driver usb-storage
[ 2.156000] Netfilter messages via NETLINK v0.30.
[ 2.160000] nf_conntrack version 0.5.0 (1956 buckets, 7824 max)
[ 2.168000] xt_time: kernel timezone is -0000
[ 2.172000] gre: GRE over IPv4 demultiplexor driver
[ 2.176000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.180000] TCP: cubic registered
[ 2.184000] NET: Registered protocol family 10
[ 2.192000] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.200000] NET: Registered protocol family 17
[ 2.204000] bridge: automatic filtering via arp/ip/ip6tables has been depreca ted. Update your scripts to load br_netfilter if you need this.
[ 2.216000] Ebtables v2.0 registered
[ 2.220000] 8021q: 802.1Q VLAN Support v1.8
[ 2.228000] VFS: Cannot open root device "(null)" or unknown-block(0,0): erro r -6
[ 2.236000] Please append a correct "root=" boot option; here are the availab le partitions:
[ 2.244000] 1f00 128 mtdblock0 (driver?)
[ 2.248000] 1f01 11520 mtdblock1 (driver?)
[ 2.256000] 1f02 4160 mtdblock2 (driver?)
[ 2.260000] 1f03 64 mtdblock3 (driver?)
[ 2.264000] 1f04 128 mtdblock4 (driver?)
[ 2.268000] 1f05 128 mtdblock5 (driver?)
[ 2.276000] 1f06 128 mtdblock6 (driver?)
[ 2.280000] 1f07 64 mtdblock7 (driver?)
[ 2.284000] 1f08 64 mtdblock8 (driver?)
[ 2.292000] Kernel panic - not syncing: VFS: Unable to mount root fs on unkno wn-block(0,0)
[ 2.292000] mtdoops: Cannot write from panic without panic_write
[ 2.292000] Rebooting in 3 seconds..
Re: 求助刷了好几个固件都卡在这里,AR9344的
帖子terra » 周四 4月 15, 2021 10:27 pm
不要配置“Boot参数替代”
