TL-WDR6300v6更新了几个固件都无法启动。
yuan1066
注册: 周四 1月 21, 2021 9:30 am
帖子yuan1066 » 周四 1月 21, 2021 9:36 am
专用UBOOT都成功了,大神帮忙看看如何处理。
TL-WDR6300 6.0 QCA9531 802.11bgn 2×2:2 802.11an/ac 2×2:2 8 MB 64 MB 支持
折腾了几天,尝试了新旧几个版本都无法启动:superwrt-qca-qca9k-pro_v0.7.30_20201120.spkg,superwrt-qca-qca9k-std_v0.2.12_20170119.spkg
开机打印信息如下:
SuperWRT Boot 1.2.1-gea7a0199-dirty (Jul 15 2016 - 10:09:14)
QCA953x - Honey Bee 2.0
DRAM: 64 MB
Flash: 8 MB (c84017)
Frequency: CPU 650MHz / RAM 597MHz / AHB 216MHz
Bootstrap Config: 0x00000000
Net: (02:54:65:72:72:61) S27wan S27 eth0, eth1
Set 0x181162c0 = 0x4b97a100
Net Command waiting: 2
eth0 link down
dup 1 speed 1000
Hit 'c' to stop autoboot: 0
config: Config magic check error!
config2: Config magic check error!
## Booting image at 9f020000 ...
Image Name: SuperWrt qca/qca9k/std
Created: 2017-01-19 7:23:33 UTC
Data Size: 1215482 Bytes = 1.2 MB
Verifying Checksum at 0x9f020178 ...OK
[ 0.000000] Linux version 3.18.40 (terra@localhost.localdomain) (gcc version 4.8.3 (SuperWrt/Linaro GCC 4.8-2014.04 r44747) ) #1 Thu Jan 19 15:22:09 CST 2017
[ 0.000000] CPU0 revision is: 00019374 (MIPS 24Kc)
[ 0.000000] SoC: Qualcomm Atheros QCA9533 ver 2 rev 0
[ 0.000000] memory: 04000000 @ 00000000 (usable)
[ 0.000000] Normal [mem 0x00000000-0x03ffffff]
[ 0.000000] node 0: [mem 0x00000000-0x03ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x00000000-0x03ffffff]
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: console=ttyS0,115200 mtdparts=spi0.0:112k(uboot),16k(SBI),7680k(firmware),64k(elog),64k(config),64k(config2),64k(custom),64k(DTB),64k(CAL) mem=64M rootfstype=squashfs,jffs2 init=/sbin/init noinitrd
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Memory: 60860K/65536K available (2884K kernel code, 139K rwdata, 388K rodata, 164K init, 99K bss, 4676K reserved)
[ 0.000000] NR_IRQS:83
[ 0.000000] Clocks: CPU:650.000MHz, DDR:597.851MHz, AHB:216.666MHz, Ref:25.000MHz
[ 0.000000] Calibrating delay loop... 431.10 BogoMIPS (lpj=862208)
[ 0.032000] pid_max: default: 4096 minimum: 301
[ 0.036000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.040000] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.044000] NET: Registered protocol family 16
[ 0.048000] MIPS: machine is SuperWRT
[ 0.052000] CPU 0 Unable to handle kernel paging request at virtual address 00000000, epc == 8006bc88, ra == 803b89b4
[ 0.056000] Oops[#1]:
[ 0.056000] CPU: 0 PID: 1 Comm: swapper Not tainted 3.18.40 #1
[ 0.056000] task: 83c28000 ti: 83c2c000 task.ti: 83c2c000
[ 0.056000] $ 0 : 00000000 00000072 0000d357 00000000
[ 0.056000] $ 4 : 00000000 00000000 00000000 801c2124
[ 0.056000] $ 8 : 00000001 00000023 83c0b000 5345514e
[ 0.056000] $12 : 81082204 81082208 00000000 00000003
[ 0.056000] $16 : 803b898c 803d3888 00000000 0000004f
[ 0.056000] $20 : 00000000 803d3858 803b7230 803e0000
[ 0.056000] $24 : 00000001 801be2b8
[ 0.056000] $28 : 83c2c000 83c2dcf8 00000000 803b89b4
[ 0.056000] Hi : 00000000
[ 0.056000] Lo : 00000000
[ 0.056000] epc : 8006bc88 0x8006bc88
[ 0.056000] Not tainted
[ 0.056000] ra : 803b89b4 0x803b89b4
[ 0.056000] Status: 1000c403 KERNEL EXL IE
[ 0.056000] Cause : 00800008
[ 0.056000] BadVA : 00000000
[ 0.056000] PrId : 00019374 (MIPS 24Kc)
[ 0.056000] Modules linked in:
[ 0.056000] Process swapper (pid: 1, threadinfo=83c2c000, task=83c28000, tls=00000000)
[ 0.056000] Stack : 83c4545c 83c55634 00000000 00000000 00000000 80330384 00000000 80360668
00000000 803545b0 00000000 00000000 803a0928 801c2124 00000000 801c05fc
83c2dd58 803a0930 803a0930 803a0930 83c4545c 00000000 803a0928 803a095c
803a0928 801c1ef0 803a0928 803aa250 00000000 803a0928 00000000 801c13f8
803a0928 803a0928 803aa250 8033006c 803a0930 803aa2b0 00000000 00000000
[ 0.056000] Call Trace:[<80330384>] 0x80330384
[ 0.056000] [<801c2124>] 0x801c2124
[ 0.056000] [<801c05fc>] 0x801c05fc
[ 0.056000] [<801c1ef0>] 0x801c1ef0
[ 0.056000] [<801c13f8>] 0x801c13f8
[ 0.056000] [<8033006c>] 0x8033006c
[ 0.056000] [<801bf830>] 0x801bf830
[ 0.056000] [<801c3504>] 0x801c3504
[ 0.056000] [<803b898c>] 0x803b898c
[ 0.056000] [<803b7230>] 0x803b7230
[ 0.056000] [<803b89b4>] 0x803b89b4
[ 0.056000] [<803c6d6c>] 0x803c6d6c
[ 0.056000] [<803ca5c0>] 0x803ca5c0
[ 0.056000] [<800698a4>] 0x800698a4
[ 0.056000] [<803d0000>] 0x803d0000
[ 0.056000] [<801be0c8>] 0x801be0c8
[ 0.056000] [<80095054>] 0x80095054
[ 0.056000] [<8009dde0>] 0x8009dde0
[ 0.056000] [<803b7b90>] 0x803b7b90
[ 0.056000] [<80065208>] 0x80065208
[ 0.056000] [<80065218>] 0x80065218
[ 0.056000] [<80060878>] 0x80060878
[ 0.056000]
[ 0.056000]
Code: afb10114 afb00110 0080a021 <94840000> 3403d357 afa000f0 a7a000f4 14830285 24020001
[ 0.060000] ---[ end trace 9ed23fc50c07c835 ]---
[ 0.064000] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 0.064000]
[ 0.064000] Rebooting in 3 seconds..
Re: TL-WDR6300v6更新了几个固件都无法启动。
帖子terra » 周四 4月 15, 2021 10:26 pm
spkg包不能直接刷,要用带硬件信息的img的文件刷机。
