各位大大
我搞了几天QCA9531+QCA9886的组合,一直没wifi
今天看TTL信息显示
WLAN1 info: cal:0x9fff5000 mac 0x9fff0006
不是应该在0x25000才对么??或者说从0x20000到往后的64K,为何显示是9fff5000???
superwrt和boot都是最新的
莫名其妙,wifi又是怎么回事。。。直接没有。。
求助:TTL显示CAL地址在9fff5000怎么回事
上次由 wlliam 在 周日 1月 27, 2019 5:02 pm,总共编辑 2 次。
Re: 求助:TTL显示CAL地址在9fff5000怎么回事
SuperWRT Boot 1.3.7-g2bf941e4-dirty (Dec 4 2017 - 17:20:59)
QCA953x - Honey Bee 2.0
DRAM: 64 MB
Flash: 16 MB (ef4018)
Frequency: CPU 650MHz / RAM 597MHz / AHB 216MHz
Bootstrap Config: 0x00001020
E313AC/u_s_s.voyager@hotmail.com/2019-01-27
WLAN1 info: cal:0x9f025000, mac:0x9f020006
Device UID: 2506b8d6e6342d3c9ae7984053c45a23
GPIO: reset(17/L), system(-1/L)
Net: (02:54:65:72:72:61) S27phy S27 eth0, eth1
Set 0x181162c0 = 0x4b97a100
Hit 'c' or 'Ctrl+c' to stop autoboot: 1
Net Command waiting: 2
Try eth1 first.
dup 1 speed 1000
config: Config magic check error!
config2: Config magic check error!
## Booting image at 9f060000 ...
Image Name: SuperWrt qca/qca9k/std-9886
Created: 2018-06-03 4:25:36 UTC
Data Size: 1251295 Bytes = 1.2 MB
Verifying Checksum at 0x9f060190 ...OK
[ 0.000000] Linux version 3.18.47 (terra@localhost.localdomain) (gcc version4.8.3 (SuperWrt/Linaro GCC 4.8-2014.04 r44747) ) #1 Sun Jun 3 12:23:46 CST 2018
[ 0.000000] CPU0 revision is: 00019374 (MIPS 24Kc)
[ 0.000000] SoC: Qualcomm Atheros QCA9533 ver 2 rev 0
[ 0.000000] memory: 04000000 @ 00000000 (usable)
[ 0.000000] Normal [mem 0x00000000-0x03ffffff]
[ 0.000000] node 0: [mem 0x00000000-0x03ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x00000000-0x03ffffff]
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32bytes
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: console=ttyS0,115200 mtdparts=spi0.0:112k(uboot),16k(SBI),64k(CAL),64k(custom),64k(config),64k(config2),16000k(firmware) mem=64M sbi=0x9f01c000 rootfstype=squashfs,jffs2 init=/sbin/init noinitrd
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Memory: 60580K/65536K available (3003K kernel code, 212K rwdata,396K rodata, 156K init, 171K bss, 4956K reserved)
[ 0.000000] NR_IRQS:51
[ 0.000000] Clocks: CPU:650.000MHz, DDR:597.900MHz, AHB:216.666MHz, Ref:25.000MHz
[ 0.000000] Calibrating delay loop... 431.10 BogoMIPS (lpj=862208)
[ 0.028000] pid_max: default: 32768 minimum: 301
[ 0.032000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.036000] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.040000] NET: Registered protocol family 16
[ 0.044000] MIPS: machine is SuperWRT
[ 0.472000] usbcore: registered new interface driver usbfs
[ 0.476000] usbcore: registered new interface driver hub
[ 0.480000] usbcore: registered new device driver usb
[ 0.484000] Switched to clocksource MIPS
[ 0.488000] NET: Registered protocol family 2
[ 0.492000] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.500000] TCP bind hash table entries: 1024 (order: 2, 20480 bytes)
[ 0.508000] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.512000] TCP: reno registered
[ 0.516000] UDP hash table entries: 256 (order: 1, 12288 bytes)
[ 0.524000] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[ 0.532000] NET: Registered protocol family 1
[ 0.536000] futex hash table entries: 256 (order: 0, 7168 bytes)
[ 0.548000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.556000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.568000] msgmni has been set to 118
[ 0.584000] io scheduler noop registered
[ 0.588000] io scheduler deadline registered (default)
[ 0.592000] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[ 0.600000] console [ttyS0] disabled
[ 0.624000] serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11, base_baud = 1562500) is a 16550A
[ 0.636000] console [ttyS0] enabled
[ 0.640000] bootconsole [early0] disabled
[ 0.660000] m25p80 spi0.0: found w25q128, expected m25p80
[ 0.668000] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.672000] 7 cmdlinepart partitions found on MTD device spi0.0
[ 0.676000] Creating 7 MTD partitions on "spi0.0":
[ 0.684000] 0x000000000000-0x00000001c000 : "uboot"
[ 0.688000] 0x00000001c000-0x000000020000 : "SBI"
[ 0.692000] 0x000000020000-0x000000030000 : "CAL"
[ 0.700000] 0x000000030000-0x000000040000 : "custom"
[ 0.704000] 0x000000040000-0x000000050000 : "config"
[ 0.712000] 0x000000050000-0x000000060000 : "config2"
[ 0.716000] 0x000000060000-0x000001000000 : "firmware"
[ 0.724000] Split rootfs Part: off:0x191970 len:0xe6e690
[ 0.728000] 0x000000191970-0x000001000000 : "rootfs"
[ 0.736000] 1 squashfs-split partitions found on MTD device rootfs
[ 0.744000] 0x0000003c1000-0x000001000000 : "rootfs_data"
[ 0.748000] mtd: device 7 (rootfs) set to be root filesystem
[ 0.772000] libphy: ag71xx_mdio: probed. phys=0x0000001f
[ 1.348000] ag71xx ag71xx.0: connected to PHY at ag71xx-mdio.1:04 [uid=004dd042, driver=Generic PHY]
[ 1.360000] eth0: Atheros AG71xx at 0xb9000000, irq 4, mode:MII
[ 1.932000] ag71xx-mdio.1: Found an AR934X built-in switch
[ 1.972000] eth1: Atheros AG71xx at 0xba000000, irq 5, mode:GMII
[ 1.980000] PPP generic driver version 2.4.2
[ 1.984000] PPP MPPE Compression module registered
[ 1.988000] NET: Registered protocol family 24
[ 1.992000] PPTP driver version 0.8.5
[ 1.996000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.004000] ehci-pci: EHCI PCI platform driver
[ 2.008000] ehci-platform: EHCI generic platform driver
[ 2.016000] ehci-platform ehci-platform: EHCI Host Controller
[ 2.020000] ehci-platform ehci-platform: new USB bus registered, assigned busnumber 1
[ 2.032000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
[ 2.048000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
[ 2.052000] hub 1-0:1.0: USB hub found
[ 2.056000] hub 1-0:1.0: 1 port detected
[ 2.064000] usbcore: registered new interface driver usblp
[ 2.068000] input: gpio-keys-polled as /devices/platform/gpio-keys-polled/input/input0
[ 2.076000] Netfilter messages via NETLINK v0.30.
[ 2.084000] nf_conntrack version 0.5.0 (946 buckets, 3784 max)
[ 2.088000] xt_time: kernel timezone is -0000
[ 2.096000] gre: GRE over IPv4 demultiplexor driver
[ 2.100000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.104000] TCP: cubic registered
[ 2.108000] NET: Registered protocol family 10
[ 2.116000] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.120000] NET: Registered protocol family 17
[ 2.128000] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 2.140000] Ebtables v2.0 registered
[ 2.144000] 8021q: 802.1Q VLAN Support v1.8
[ 2.156000] VFS: Mounted root (squashfs filesystem) readonly on device 31:7.
[ 2.164000] Freeing unused kernel memory: 156K (803e9000 - 80410000)
init started: BusyBox v1.22.1 (2018-06-03 12:18:18 CST)
starting pid 299, tty '': 'sh /etc/init.d/rcS S start'
mount: mounting usbfs on /proc/bus/usb failed: No such file or directory
mount: mounting nodev on /sys/kernel/debug failed: No such file or directory
Fri Jan 1 00:00:00 UTC 2010
Try backup config
[ 4.480000] Loading modules backported from Linux version wt-2016-10-03-1-g6fcb1a6
[ 4.488000] Backport generated by backports.git backports-20160324-9-g0e38f5c
[ 4.956000] swd: module license 'Proprietary' taints kernel.
[ 4.964000] Disabling lock debugging due to kernel taint
[ 4.972000] SuperWRT Network Engine installed!
[ 5.648000] random: svld urandom read with 22 bits of entropy available
[ 7.044000] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 7.052000] device eth1 entered promiscuous mode
[ 7.064000] IPv6: ADDRCONF(NETDEV_UP): lan: link is not ready
[ 7.240000] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
udhcpc (v1.22.1) started
Setting IP address 0.0.0.0 on eth0
Sending discover...
[ 8.644000] eth1: link up (1000Mbps/Full duplex)
[ 8.648000] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 8.656000] lan: port 1(eth1) entered forwarding state
[ 8.660000] lan: port 1(eth1) entered forwarding state
[ 8.668000] IPv6: ADDRCONF(NETDEV_CHANGE): lan: link becomes ready
Sending discover...
Sending discover...
no schk found; none killed
Jan 1 08:00:11 crond[723]: crond: crond (busybox 1.22.1) started, log level 8.random: 600737216.
Please press Enter to activate this console.
DRAM: 64 MB
Try eth1 first.
dup 1 speed 1000
Try backup config
Sending discover...
Sending discover...
Sending discover...
