U-Boot 1.1.4-g67d96d8d-dirty (Feb 2 2016 - 15:37:40)
QCA953x - Honey Bee 2.0
DRAM: 32 MB
Unkonw try using 16 MB
Flash: 16 MB (1c7015)
Bootstrap Config: 0x00000421
TP WR842N v7.0/terra@superwrt.com/2016-02-02
GPIO: reset(17/L), system(13/L)
Net: (bc:46:99:af:a5:34) S27wan S27 eth0, eth1
Setting 0x181162c0 to 0x4b97a100
Hit any key to stop autoboot: 0
## Booting image at 9f028000 ...
出现上面的启动信息后,路由全部的灯都亮了,电脑无法获得IP地址,设置为192.168.1.x也不能进入网页
UBOOT刷入方法是按网页教程TTL刷入的
[新:ROM不能启动]TP-W842N V7用TTL刷入UBOOT后启动不了,信息如下:
上次由 baibye 在 周五 4月 22, 2016 2:56 pm,总共编辑 1 次。
Re: TP-W842N V7用TTL刷入UBOOT后启无不了,信息如下:
baibye 写了:U-Boot 1.1.4-g67d96d8d-dirty (Feb 2 2016 - 15:37:40)
DRAM: 32 MB
你没有按住复位键,或者是你的复位键的GPIO设置错了。可以在打印Hit any key to stop autoboot时,输入任意键进入uboot。然后在uboot上输入http来启动http服务。
按版主提供的方法启动HTTP,刷入superwrt-qca-ar934x-tiny_v0.0.8_20160327.spkg后,路由无法启动
* 闪存为2MB,BREED能正常识别 *
启动信息如下:
DRAM: 32 MB
Bootstrap Config: 0x00001421
Setting 0x181162c0 to 0x913a100
Magic: 56
Bad Magic Number
Failed to boot.
Starting httpd to update firmware...
dup 1 speed 1000
starting httpd server eth1 192.168.17.1
Alloc 192.168.17.3 to xx:xx:xx:xx:xx:xx
刷入ROM时的信息如下:
ath> http
dup 1 speed 1000
Alloc 192.168.17.3 to 00:xx:xx:xx:xx:xx
Request for: /
Request for: /style.css
Request for: /favicon.ico
File not found!
Alloc 192.168.17.3 to 00:e0:b6:0c:3a:d2
Data will be downloaded at 0x80060000 in RAM
Upload file size: 1880728 bytes
Image magic: 5370eb67
Write firmware (0x1cb15c) to 0x9f028000 (0x1d8000)
Error: start address not on sector boundary
Copy to Flash... write addr: 9f028000
done
BREED启动信息如下:
Boot and Recovery Environment for Embedded Devices
Copyright (C) 2016 HackPascal <hackpascal@gmail.com>
Build date 2016-04-19 [git-3b445d3]
Version 1.0 (r849)
DRAM: 32MB
Platform: Qualcomm Atheros QCA953X rev 2
Board: Generic board
Clocks: CPU: 550MHz, DDR: 400MHz, AHB: 200MHz, Ref: 25MHz
Flash: EON EN25QH16 (2MB) on ath79-spi
ag71xx-eth: MAC address is invalid, using default settings.
ag71xx-eth: Using MAC address 00:13:74:00:00:01
eth0: Atheros AR8228/AR8229 rev 1
Network started on eth0, inet addr 192.168.1.1, netmask 255.255.255.0
Press any key to interrupt autoboot ... 2
Autoboot aborted due to key press.
Starting breed built-in shell
BREED能不能启动版主提供的ROM?谢谢
启动信息如下:
DRAM: 32 MB
Magic: 56
Bad Magic Number
Failed to boot.
dup 1 speed 1000
刷入ROM时的信息如下:
ath> http
dup 1 speed 1000
Request for: /
File not found!
done
BREED启动信息如下:
Version 1.0 (r849)
DRAM: 32MB
baibye 写了:按版主提供的方法启动HTTP,刷入superwrt-qca-ar934x-tiny_v0.0.8_20160327.spkg后,路由无法启动
启动信息如下:
DRAM: 32 MB
Magic: 56
Bad Magic Number
Failed to boot.
dup 1 speed 1000
刷入ROM时的信息如下:
ath> http
dup 1 speed 1000
Request for: /
File not found!
done
BREED启动信息如下:
Version 1.0 (r849)
DRAM: 32MB
是Flash型号我的boot没认出来,然后你直接使用886N的分区方式是不行的,因为那个要求是4k erase的Flash。没认别的Flash默认不支持该操作。
你需要自己再做一下Flash分区,做成以64k对齐的。或者等我把1c7015这种Flash加入boot代码里。
Breed不能启动我的系统,因为它带有了设备信息过来。
