886V4刷好最新版固件无无线信号了!请教大神怎样刷art!
八进制
注册: 周三 12月 09, 2015 8:49 am
帖子由 八进制 » 周二 12月 27, 2016 2:23 pm
我的886V4刷好最新版uboot和固件以后,没有无线信号请教大神如何刷如art!
SuperWRT Boot 1.2.5-g76975354-dirty (Nov 29 2016 - 15:22:48)
QCA956x - Dragonfly 1.0
DRAM: 16 MB
Flash: 2 MB (c84015)
Frequency: CPU 750MHz / RAM 400MHz / AHB 250MHz
Bootstrap Config: 0x00001c0b
TP WR886N v5/terra@superwrt.com/2015-12-10
WLAN0 info: cal:0x9f020800, mac:0x9f020000
Device UID: none
GPIO: reset(1/L), system(18/L)
Net: (b4:24:1e:e4:2f:82) S27phy S27 eth0, eth1
Set 0x181162c0 = 0x4b962100
Net Command waiting: 2
Try eth1 first.
dup 1 speed 1000
Hit 'c' to stop autoboot: 0
config: Config magic check error!
## Booting image at 9f028000 ...
Image Name: SuperWrt qca/qca9k/tiny
Created: 2016-12-02 2:27:29 UTC
Data Size: 926525 Bytes = 904.8 kB
Verifying Checksum at 0x9f028178 ...OK
[ 0.000000] Linux version 3.18.40 (terra@localhost.localdomain) (gcc version 4.8.3 (SuperWrt/Linaro GCC 4.8-2014.04 r44747) ) #1 Fri Dec 2 10:26:05 CST 2016
[ 0.000000] CPU0 revision is: 00019750 (MIPS 74Kc)
[ 0.000000] SoC: Qualcomm Atheros TP9343 rev 0
[ 0.000000] memory: 01000000 @ 00000000 (usable)
[ 0.000000] Normal [mem 0x00000000-0x00ffffff]
[ 0.000000] node 0: [mem 0x00000000-0x00ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x00000000-0x00ffffff]
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping off. Total pages: 4064
[ 0.000000] Kernel command line: console=ttyS0,115200 mtdparts=spi0.0:112k(uboot),8k(SBI),8k(custom),4k(CAL),28k(config),1888k(firmware) mem=16M sbi=0x9f01c000 rootfstype=squashfs,jffs2 init=/sbin/init noinitrd
[ 0.000000] PID hash table entries: 64 (order: -4, 256 bytes)
[ 0.000000] Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Memory: 12980K/16384K available (2185K kernel code, 111K rwdata, 284K rodata, 160K init, 79K bss, 3404K reserved)
[ 0.000000] NR_IRQS:83
[ 0.000000] Clocks: CPU:750.000MHz, DDR:400.000MHz, AHB:250.000MHz, Ref:25.000MHz
[ 0.000000] Calibrating delay loop... 374.78 BogoMIPS (lpj=749568)
[ 0.032000] pid_max: default: 4096 minimum: 301
[ 0.036000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.040000] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.044000] NET: Registered protocol family 16
[ 0.048000] MIPS: machine is SuperWRT
[ 0.468000] Switched to clocksource MIPS
[ 0.472000] NET: Registered protocol family 2
[ 0.476000] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.484000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.492000] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.500000] TCP: reno registered
[ 0.504000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.508000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.516000] NET: Registered protocol family 1
[ 0.524000] futex hash table entries: 16 (order: -5, 192 bytes)
[ 0.532000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.540000] msgmni has been set to 25
[ 0.544000] io scheduler noop registered
[ 0.548000] io scheduler deadline registered (default)
[ 0.556000] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[ 0.564000] console [ttyS0] disabled
[ 0.588000] serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11, base_baud = 1562500) is a 16550A
[ 0.596000] console [ttyS0] enabled
[ 0.604000] bootconsole [early0] disabled
[ 0.616000] m25p80 spi0.0: found gd25q16, expected m25p80
[ 0.620000] m25p80 spi0.0: gd25q16 (2048 Kbytes)
[ 0.624000] 6 cmdlinepart partitions found on MTD device spi0.0
[ 0.632000] Creating 6 MTD partitions on "spi0.0":
[ 0.636000] 0x000000000000-0x00000001c000 : "uboot"
[ 0.640000] 0x00000001c000-0x00000001e000 : "SBI"
[ 0.648000] 0x00000001e000-0x000000020000 : "custom"
[ 0.652000] 0x000000020000-0x000000021000 : "CAL"
[ 0.660000] 0x000000021000-0x000000028000 : "config"
[ 0.664000] 0x000000028000-0x000000200000 : "firmware"
[ 0.668000] Split rootfs Part: off:f5b48 len:0
[ 0.676000] 0x00000010a4b8-0x000000200000 : "rootfs"
[ 0.680000] mtd: device 6 (rootfs) set to be root filesystem
[ 0.688000] 1 squashfs-split partitions found on MTD device rootfs
[ 0.692000] 0x0000001fb000-0x000000200000 : "rootfs_data"
[ 0.704000] libphy: ag71xx_mdio: probed. phys=0x0000001f
[ 1.280000] ag71xx ag71xx.0: connected to PHY at ag71xx-mdio.1:04 [uid=004dd042, driver=Generic PHY]
[ 1.288000] eth0: Atheros AG71xx at 0xb9000000, irq 4, mode:MII
[ 1.864000] ag71xx-mdio.1: Found an AR934X built-in switch
[ 1.904000] eth1: Atheros AG71xx at 0xba000000, irq 5, mode:GMII
[ 1.908000] PPP generic driver version 2.4.2
[ 1.916000] NET: Registered protocol family 24
[ 1.920000] input: gpio-keys-polled as /devices/platform/gpio-keys-polled/input/input0
[ 1.928000] nf_conntrack version 0.5.0 (202 buckets, 808 max)
请教大神art应该刷到哪个地址!
Re: 886V4刷好最新版固件无无线信号了!请教大神怎样刷art!
帖子由 terra » 周二 12月 27, 2016 2:45 pm
八进制 写了:我的886V4刷好最新版uboot和固件以后,没有无线信号请教大神如何刷如art!
DRAM: 16 MB
Device UID: none
Try eth1 first.
dup 1 speed 1000
请教大神art应该刷到哪个地址!
在boot启动时WLAN info中的cal地址就是。
八进制
帖子由 八进制 » 周二 12月 27, 2016 3:42 pm
感谢大神! :lol:
八进制
帖子由 八进制 » 周二 12月 27, 2016 4:07 pm
在debug下显示的WLAN0 info: cal:0x20800,但是在TTL超级终端下显示的是WLAN0 info: cal:0x9f020800,到底该怎么填,我把两个地址都测试了,系统不停的重启,辛亏不是不死uboot,可以重新刷机,要不就要上编程器了!
